3x PACK DENSO QS20H BARCODE HANDSCANNER READER RS-232 KASSE POS SCANNER NETZTEIL
68,31 €
Kategorie BarCode Scanner
3x Stück Barcode / 2D Handscanner Denso
Model: QS20H
Getestet - ok!
Lieferumfang: 3x Scanner, Netzteil, Kabel, Ständer - wie abgebildet!
Ohne Drivers/Sofware (without Drivers/Sofware)
Specifications:
Mechanical:
Dimensions 163 mm (l) x 72 mm (h) x 54 mm (w) / Weight 230g (including cable)
Environmental: Operating Temp. 0°C to 40°C / Storage Temp. -10°C to 60°C
Electrical:
Operating Current 1A Max.
Drive Voltage 4.5 - 10 V/DC
Optical:
Scan Engine: CCD
Illumination: Flashing LED with triple LED pointer
Depth of Field:40 - 200 mm
Linear Symbologies Decoded: EAN/UPC, Code 39, NW-7, Interleave 2 of 5, Code 128
2 D Symbologies Decoded: QR Code, Micro QR Code, PDF-417, Maxicode, DataMatrix
Communications:
Cable Options RS232
Lieferumfang: 3x Scanners, Netzteil, Kabel, Ständer- wie abgebildet!
Lager N: Scan_2-02
